Old     (01centurion)      Join Date: Jun 2010       04-10-2011, 8:25 PM Reply
i have an 01 skin centurion an with the bilge pump switch off once i turn the batteries on the pump kicks on.. i try to over ride it with the switch but it does not shut it off.. anyone ever have this happen or have any ideas? im thinking if there is some kinda float that it might be stuck...
thanks
Old     (wake_upppp)      Join Date: Nov 2003       04-10-2011, 10:28 PM Reply
If it is an automatic bilge pump with a float then most likely yes the float is stuck.
Old     (bbeach)      Join Date: Jul 2002       04-11-2011, 7:37 AM Reply
is your plug in?! haha
Old     (dreamer)      Join Date: Nov 2008       04-11-2011, 7:40 AM Reply
Give it a tap with a hammer or something. The float is probably stuck. That happened on my enzo once and a quick little tap did the trick
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-11-2011, 1:45 PM Reply
Does it have 'on' and 'auto'? I'd prolly replace it anyway. Something's causing it to stick and I wouldn't trust the pump going forward. 30 bucks or so should get u going and would be cheap peace of mind.
Old     (wakeboard247)      Join Date: Feb 2011       04-11-2011, 2:11 PM Reply
Sounds like the float is stuck. The same thing happened on my malibu. Take it apart, clean it and put it back together. Should work like new after that......and will save you a little coin (the pump I cleaned was 2 years ago and its still going strong).
