Old     (Gotmods)      Join Date: Nov 2012       07-06-2016, 1:52 PM Reply
Can you rotate the grills on the Rev 10's so they're correctly oriented when installing on the curved part of the tower? I saw nothing in the instructions so I thought I'd ask. I assume you can.
Old     (trayson)      Join Date: May 2013 Location: Vancouver WA       07-06-2016, 2:37 PM Reply
there are 8 screws in the grills of the REV speakers. so you can rotate them into 8 different positions. At least that's how they are on my REV410's.
Old     (Gotmods)      Join Date: Nov 2012       07-06-2016, 3:09 PM Reply
Do you have a picture?
Old     (trayson)      Join Date: May 2013 Location: Vancouver WA       07-06-2016, 3:14 PM Reply
you can see 4 of the screws here. the other 4 screws are under the grill holding the woofer in.
Old     (bcrider)      Join Date: Apr 2006       07-06-2016, 4:43 PM Reply
The answer is yes Rob, I just did this on my Tige as they are side/angle mount. You just rotate the grill to the next set of holes to the desired location.
Old     (Gotmods)      Join Date: Nov 2012       07-16-2016, 6:25 PM Reply
Can I make new holes in the correct orientation if no existing ones work? Is the housing just plastic? Then I'd just put a dab of silicone in the 4 unused holes.
Old     (markj)      Join Date: Apr 2005       07-16-2016, 11:44 PM Reply
Bingo! Yes.
Old     (Gotmods)      Join Date: Nov 2012       07-17-2016, 1:26 AM Reply
Originally Posted by markj View Post
Bingo! Yes.
Someone who's done this. Thanks!
