Old    boarderrr            09-09-2014, 4:20 PM Reply
How much does a system 2.0 cost? Or any type of the two tower system for that matter? Also how much water (length, width) would you need. So all together how much would the installation, delivery, and to make the pond from scratch? Is there even any of the two tower systems for 20,000? (But still great quality)
Old     (Jmaxymek)      Join Date: Feb 2012       09-09-2014, 4:51 PM Reply
Sesi System 2.0s are something around 40k if I remember correctly. You don't want to span one much further than 700 or so feet, otherwise you get a lot of sway in the line (so I've been told). Width is up to you... Making a pond from scratch would require excavation equipment and permits and etc.. You're not looking at a relatively cheap setup. If it's for a business, insurance and build permits from the city are also a pain.
Old     (logan)      Join Date: Dec 2011       09-09-2014, 10:51 PM Reply
One way to do this more affordably would be to excavate X feet of dirt and then use that material to build a berm or levy around the excavation. You would need a liner of sort, there are different plastics that can be welded and are water tight. You would need something heavy enough to be able to melt and weld and also heavy enough in the event a board were to hit it.
