Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (schuey)      Join Date: Apr 2005       07-10-2008, 10:30 AM Reply
Not knowing much about fat sacs, what are the best sacs to get? Who makes 440lb sacs for each side of the engine compartment? Do you need to buy the pump seperately? Can they interconnect or do you need two pumps or to pump each one up seperately? How long does it take to fill a 440lb sac? And is emptying them the same as filling them up, just using the pump on reverse?
Old     (scrupulous)      Join Date: Jun 2006       07-10-2008, 10:33 AM Reply
I use the V-Drive set, pair of 400 pounders. Quick Connect fittings are the best. Snag a Tsunami pump and you should be set. Unless you want to plumb in ballast...
http://www.fatsac.com/FlyHigh/FlyHighSacs.html
Old     (justcoz5)      Join Date: Apr 2007       07-10-2008, 2:55 PM Reply
Yes you need to buy the pump, it doesn't come with the sacs. You fill them up one at a time, so you only need one pump. It takes about 5-10 min to fill one up.
Old     (deltaboy)      Join Date: Jan 2007       07-10-2008, 3:02 PM Reply
http://www.onlyinboards.com/Ski-boat-accessories/fat-sacks.html
A set of Pro X series Nautique 440# sac's and a Tsunami is just under $300
Old     (schuey)      Join Date: Apr 2005       07-11-2008, 4:39 AM Reply
Does the Tsunami pump come with the quick connect fittings or do you have to buy them seperately?
Thanks
