Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 17, 2004
Old     (typhoon)      Join Date: Jul 2001       01-26-2004, 4:13 PM Reply
our friends have a four winns and when they hit it it hesitates. any suggestions? the carb has been checked out already.
thanks
Old     (hatepwcs)      Join Date: Mar 2002       01-26-2004, 4:14 PM Reply
Fuel Filter, and stop lying. We know you traded the Sanger for the Four Winns.
Old    walt            01-26-2004, 4:21 PM Reply
Does it have a Q-jet Carb ?
Old     (goth2o)      Join Date: Sep 2003       01-26-2004, 4:38 PM Reply
cap and rotor? distributor? just a thought
Old     (882001)      Join Date: Nov 2003       01-26-2004, 4:49 PM Reply
full tune up srark plugs, cap, rotor,wires, check timing, fuel filter. will usually fix it
Old    g3revenge            01-26-2004, 5:16 PM Reply
ever cleaned the spark/flame arrestor?
Old     (whazzup)      Join Date: Oct 2001       01-26-2004, 8:59 PM Reply
Maybe its the anti-siphon valve at the fuel tank. Sometimes junk prevents it from opening fully.
Old     (socalwakepunk)      Join Date: Dec 2002       01-26-2004, 9:19 PM Reply
Either fuel system or ignition. A friend had an OMC 5.7L, it shot ducks under load (pulling up a rider), but planed off just fine with no rider. Turned out to be ignition (spark plug) wires.
Old     (peter_c)      Join Date: Sep 2001       01-26-2004, 10:57 PM Reply
Bad accelerator pump in the carb? That would be the most likely cause. Usually feels like you cut the throttle for a second not opened it.
Old     (typhoon)      Join Date: Jul 2001       01-27-2004, 6:30 AM Reply
holly carb.
Old     (typhoon)      Join Date: Jul 2001       01-27-2004, 6:32 AM Reply
it acts like the accellerator pump peter.
Old    g3revenge            01-27-2004, 6:34 AM Reply
power valve on the holley been checked?
if you have a hose, fire up the engine at night. this will show any erant sparks. if you have a good ear , you can hear them.
i agree with 88. try a tune up. it's not a toyota.
(Message edited by g3revenge on January 27, 2004)
Old     (phili)      Join Date: Jan 2004       02-05-2004, 5:05 AM Reply
My nautique did the same thing. It turned out to be the "Fuel Metering Plate" on the Holly carb. Put new one in and as run fine since.
Old     (phili)      Join Date: Jan 2004       02-05-2004, 5:07 AM Reply
My nautique did the same thing. It turned out to be the "Fuel Metering Plate" on the Holly carb. Put new one in and has run fine since.
Old    tigejohn21i            02-05-2004, 12:55 PM Reply
If it hesitates, but slowly winds out to nice rpm and sounds ok, the timing may need to be adjusted.
