Old     (hillbilly)      Join Date: Aug 2002       04-20-2008, 8:25 AM Reply
Would the manual for a marine vs. auto engine be the same as far as the front cover? Meaning removing the front timing cover and bolt torque specs and what not? Thanks Jeff
Old     (wake_upppp)      Join Date: Nov 2003       04-20-2008, 9:34 AM Reply
Yes it should be the same for what your doing.
Old     (luchog)      Join Date: Jun 2002       04-20-2008, 8:55 PM Reply
timing cover for the marine app has different mounting brackets for the alternator and water pump.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-20-2008, 9:10 PM Reply
should be the same. what does it say? my SBF manual doesn't list a torque spec for the timing cover, however.
Old     (hillbilly)      Join Date: Aug 2002       04-20-2008, 9:34 PM Reply
I didn't see it in there either. I just picked up a Hanes sbf rebuild manual from Autozone. I got the timing cover off now I am playing heck getting 2 broken bolts out from the impeller that broke off at the block. Any tips
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-20-2008, 9:59 PM Reply
didn't take my water pump apart, so i'm having a hard time picturing whats going on. shoot a pic of it.
Old     (hillbilly)      Join Date: Aug 2002       04-20-2008, 10:14 PM Reply
I pulled the entire front of my motor off. Timing chain exposed. I had broken an impeller bracket bolt off a long time ago. Well then I had stringers replaced. Fast fwd a couple yrs and now I am finally getting around to fixing the bolt.So it is in my garage and I need to remove the broken bolt and another bolt I broke while taking apart the motor.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-20-2008, 10:21 PM Reply
gotcha. You need someone to drill it out and retap (rethread) the hole for use with a larger bolt. Find a machine shop.
Old     (mkperceptions)      Join Date: Jan 2007       04-20-2008, 10:27 PM Reply
YEa if you are really good with a drill use a punch and punch small mark in the center of the broken bolt. They use a small drill bit and drill a hole. then a bigger and bigger and bigger bit untill you are almost at the threads then there should just be a shell of the bolt left and use a small screwdriver and bent it and pull it out. I wouldnt worry about torqueing the chain cover. Just tighten it snug
