Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 01, 2004
Old     (hillbilly)      Join Date: Aug 2002       03-30-2004, 2:21 PM Reply
I have an old 84 correct craft trailer and I need to replace the bunks on the rails. Is there a certain type of wood or just any 2x4 would work? And how hard is it to get it to take the curve of the trailer. And do you know what the angle is on the wood....45% or something...THANKS JEFF
Old     (jklein)      Join Date: May 2001       03-30-2004, 3:24 PM Reply
When I replaced mine, I used pressure treated wood. My bunks are not really curved at all so I can't help you there.
Old    walt            03-30-2004, 3:34 PM Reply
You can buy them pre made. But if you make them I would use pressure treated. The 2x4 will conform to your boats shape in no time.
Old     (hillbilly)      Join Date: Aug 2002       03-31-2004, 2:09 AM Reply
Thanks....About pre-made where would they have those?.....WESTMARINE maybe...
Old    walt            03-31-2004, 4:36 AM Reply
That would be a good place to try but I bought mine from a local marine mechanic.
Old     (tre)      Join Date: Jul 2002 Location: WI       03-31-2004, 7:34 AM Reply
I am not sure if pressure treated wood is a good idea. There seems to be some debate about the safety of the chemicals used in pressure treated wood. I don't know if you want to put that into your lake.
Old     (mastercraft1995)      Join Date: Nov 2002       03-31-2004, 8:02 AM Reply
Pressure treated is the way to go. Not to bash on you tre but what about all the 2 stroker's on the lake, and chemicals from your lawn. Pressure treated wood in the lake for 1 minutes isn't going to do anything to the lake.
Old    ag4ever            03-31-2004, 8:55 AM Reply
I use pressure treated for my dock, so why would I not use it for my trailer.
BTW, there is more than one type of pressure treated lumber. Some safer than others.
Old     (superairdawg)      Join Date: May 2003       03-31-2004, 9:47 AM Reply
Well, you can use regular 2x4 if you're that environmentally conscious, but it won't last very long. You'll probably end up replacing again in a couple years. The pressure treated is more water resistant. I'm assuming you have the "wishbone" bunk trailer with curved bunks. I don't think the cut angle is critical but it's close to 45 degrees. When I replaced the bunks on my '79 CC trailer I just eyeballed the cuts and blasted away with a circular saw.. No worries and you couldn't even tell once I recarpeted it. Getting the curve of the trailer wasn't difficult, either. Just work your way down with the through-bolts bending as you go. Cake...
Old    cisom            03-31-2004, 10:44 AM Reply
Actually the wood in the bunks is generally cypress, it can take all the wet/dry conditions and last. Where can you find it? Good question, start calling REAL lumberyards--not Home Depot or Lowes.
Old     (hillbilly)      Join Date: Aug 2002       04-01-2004, 2:43 AM Reply
Thanks guys got to get on the trailer this weekend boat should be back from the shop soon.
