Old     (Tripj3)      Join Date: Oct 2012       05-31-2016, 6:49 PM Reply
I have a 2001Ski nautique anniversary edition that has I believe has an origami tower also..at least it looks that way. The dash control panel looks like the same as it would for a nautique air so it has a ballast fill and empty button but of course it does work as there is no system. I was wondering if I could install an aftermarket system?
Jim
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-01-2016, 8:46 AM Reply
hell yea!
Old     (dvsone79)      Join Date: Dec 2012       06-01-2016, 11:11 AM Reply
Give the guys at wakemakers.com a call. They'll tell you everything you need and provide great customer service.
Old     (sidekicknicholas)      Join Date: Mar 2007       06-01-2016, 11:29 AM Reply
+1 for wakemarkers .... they'll be able to help you out big time.
Not sure if having rear ballast on a switch is much better then throwing a pump over the side though with a direct drive. I would assume you want to pick/move the bags when not full... so having it plumbed it might not be the best option.
The bow on the other hand (assuming you have a closed bow) would be nice to have plumbed in since it would rarely be moved.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-02-2016, 1:39 PM Reply
so do you have rear storage? if so, I would plumb in ballast and leave bags tucked away in rear storage. pull them out and use some quick connects to hook up your hose. could be really clean if done right.
