Old     (NoCO570)      Join Date: Mar 2016       07-09-2018, 12:59 PM Reply
2006 Sanger V215 with Merc Black Scorpion motor- started out from dock unable to accelerate past no wake speed, even under full throttle motor was not responding much and sounded rough. Oil pressure gauge was jumping, temp went high. So I turned it off and restarted after a short pause. Temp gauge immediately went down to normal running temp and oil pressure stabilized. Boat ran fine the rest of the day. Trying to figure out what caused this, maybe impeller stuck or intake clogged?
Old     (dlowry81)      Join Date: Jul 2018       07-09-2018, 1:18 PM Reply
My vote would be intake clogged which caused you to go into limp mode, but that doesn't explain the oil pressure jumping.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-17-2018, 9:34 AM Reply
have your alt tested
Old     (Michael)      Join Date: Mar 2010       07-17-2018, 9:52 AM Reply
The first thing I would do would check the oil level, specifically if you have too much.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-17-2018, 9:59 AM Reply
if alt is fine, give your grounds, battery terminals and cables a good once over. something electrical is going on, could also cause it to go into limp mode. could have just built up corrosion while stored
