Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through January 28, 2006
Old     (fergie23)      Join Date: Sep 2004       01-28-2006, 9:31 AM Reply
OK, this may be the dumbest question ever but I am trying to put a Malibu decal on the back window of my truck. What is the best way to make sure it adheres well? I have put many stickers on but this one seems different. I peeled off top layer, placed it on the clean windown, but the actual decal is still stuck to the backing and even rubbing it doesn't seem to make it adhere. What am I doing wrong??? Thanks
Old     (john_v96)      Join Date: Apr 2003       01-28-2006, 10:27 AM Reply
clean the area well with rubbing alchol, and you have to get the sticker wet and also the window then put the sticker were you like then take a credit card or drivers lic and push all the water and air pockets out from under the sticker. should worl fine
Old     (fergie23)      Join Date: Sep 2004       01-28-2006, 10:36 AM Reply
Thanks johnny, I will try that!
Old     (kybool)      Join Date: Aug 2004       01-28-2006, 10:52 AM Reply
the back of a spoon also works good, at least if it's a die-cut sticker. Just rub the bottom part of the spoon over the sticker real good.
Old     (extremeisaac)      Join Date: Aug 2005       01-28-2006, 11:19 AM Reply
soapy water works really really good... spray the back of your windows with soapy water..apply the sticker.. then you can move it around to make sure that its center and everything.. like johnny said.. use a credit card or some sort of plastic to work out the air bubbles.. leave it in the sun to dry for about 20-30 minutes
Old     (fergie23)      Join Date: Sep 2004       01-28-2006, 12:08 PM Reply
found another good use for a credit card! thx
