Old     (Stoken)      Join Date: Jun 2016       06-28-2016, 9:29 AM Reply
Has 1000 lbs on each side in back and factory bags in front and wave is short and breaks fast just can't seem to get it right, disappointed in it, any help would be much appreciated
Old     (ragboy)      Join Date: Aug 2007       06-28-2016, 7:18 PM Reply
This video was done a few years ago with a 2010 RZ2:
Fill the front up all the way, it should be about 800 lbs, if you don't have 800 lbs up there, you will want that, and then the surf corner needs enough weight so that when you are surfing in calm water the rub rail is touching or in the water. It will be listed a good 15 degrees or so, but it will make a great wake.
Old     (Stoken)      Join Date: Jun 2016       06-28-2016, 7:58 PM Reply
Idk how much is up front now, but I will put 800 lbs up there, do u put any weight on none surf side, and should I just mess with the taps to get wake right
Old     (ragboy)      Join Date: Aug 2007       06-28-2016, 8:18 PM Reply
not much on non surf side, put taps at 3-4 to start, but you can adjust. once you get that rub rail down, you can add some weight to the opposite side until it starts to get dirty or a cut in the lip, then take opposite weight out. The best wake is when the wake JUST gets clean.
Old     (Stoken)      Join Date: Jun 2016       06-28-2016, 8:38 PM Reply
Thank u very much I will try it out, I was pretty disappointed in this boat when I first took it out
Old     (ragboy)      Join Date: Aug 2007       06-28-2016, 8:49 PM Reply
Don't worry, that boat makes a great wave and you will enjoy it. Its old school, and requires a good list, but it a good wakesurf hull.
Old     (Wagonhound)      Join Date: Aug 2015       07-01-2016, 8:30 PM Reply
I run 800 lbs in the rear locker, 800 lbs on the rear seat, 400lbs of lead in the bow. I have a 2008 so your wake should be cleaner with that small swim platform. Once you can learn to surf around 12mph with a capable board, your boat with throw a hell of a fun wake.
Old     (Stoken)      Join Date: Jun 2016       07-09-2016, 6:20 AM Reply
Can I retro fit the convo vx on on my 2011 rz2
Old     (ragboy)      Join Date: Aug 2007       07-09-2016, 12:36 PM Reply
If you fix that platform, you will have a MUCH better wake.
Old     (Wagonhound)      Join Date: Aug 2015       07-26-2016, 8:55 PM Reply
Wakeshaper, 800lbs in each locker, 400lb in the bow, and getting to add another 600 on the back floor when we don't have enough guests riding.
