Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 16, 2009
Old     (bear)      Join Date: Apr 2005       11-01-2009, 8:54 PM Reply
Hey guys here's my question: I currently have an 07 premier and I used to ride an 02 DNA premier. I like the way it tracks and the way it rides but I'm looking for something that weighs less than the 07 (it's a brink) and has more pop. I'm thinking about the Ronix One since it's Harfs model, so it must be somewhat similer but I've read on here that it takes alot of getting used to. I was also thinking about the ibex? Any thoughts? Like I said I want something that tracks and rides similar to the premier but more pop. Oh and I ride the premier with out the center fin. thanks
Old     (dakid)      Join Date: Feb 2001       11-01-2009, 9:14 PM Reply
liquid force shane
what's a brink?
Old     (wakerpunk)      Join Date: Jan 2006       11-01-2009, 9:16 PM Reply
i think he meant brick
Old     (bear)      Join Date: Apr 2005       11-01-2009, 9:24 PM Reply
yeah sorry i meant the 07 premier is very heavy.
Old     (tom_paz)      Join Date: Jan 2003       11-01-2009, 10:55 PM Reply
Byerly Monarch is like the premier 2.0. a little faster and looser, a little harder pop but very similar. it has a similar profile and much much lighter. the 08/09 was made with a pvc core and weighed 6.5 lbs, but was kinda expensive. the '10 uses a polyurethane (foam) core so it is a little heavier than pvc core (~8 lbs, still WAY lighter than premier) and costs under $400. check it out, you won't be disappointed. its seriously like the premier reborn. i also hear good things from the '10 HL B-side, been told its sorta like the hyperlite version of the monarch.
Old     (kristian)      Join Date: Nov 2002       11-02-2009, 1:24 AM Reply
Demo the One if you can but danny did change up a lot from his premier. Its a much more carvy surfy feel.
Try out the 08/09 Mana, many premier riders really liked it. From what you say you want it sounds like it would be the ticket.
Old    alanp            11-02-2009, 5:03 AM Reply
the one
Old     (dudeman)      Join Date: Mar 2005       11-02-2009, 5:14 AM Reply
I was riding the One and couldn't get the hang of it. I'm now on the Shane.
Old     (jrich)      Join Date: Oct 2009       11-02-2009, 5:25 AM Reply
I rode a 136 lyman a couple weeks ago and that is the board i'm getting for next year. that board has more pop than anything i have ever ridden. Like said ab the one though it takes some getting used to.
Old    wakejjboard12            11-02-2009, 5:37 AM Reply
08/09 Mana or the witness.
Old     (bear)      Join Date: Apr 2005       11-02-2009, 7:44 AM Reply
can someone explain to me what they mean by the Ronix one takes some getting used to and why some many people say they couldn't get the hang of it? What is it, the timing of the pop or is it how it rides in the water or what please explain.
Old     (tampawake)      Join Date: Mar 2008       11-02-2009, 7:56 AM Reply
I had a ONE just did not like it but I suck. A couple friends have them and LOVE them. Ended up getting an IBEX 138 which I liked a lot then a friend got me on a SS Recoil and bam LOVE this board. Its a 142 and super light weight but real loose better know how to ride your edges. The ibex was loose too. Still have the Ibex if you might be interested in that. Good luck.
Old     (steezyshots)      Join Date: Feb 2008       11-02-2009, 8:21 AM Reply
Check out the 2010 B side! So sick!
Old     (spearing)      Join Date: Sep 2005       11-02-2009, 9:23 AM Reply
Byerly monarch i felt was very close, it does pop harder.
Old     (sp0tts)      Join Date: Jun 2004       11-02-2009, 9:27 AM Reply
I rode the Premier for a long time and just switched to the Liquid Force Witness this year. The Witness has more pop, but is still a smooth popping board and lands really soft, also faster than the Premier, haven't been on a board I like better than the Witness....
Old     (sidekicknicholas)      Join Date: Mar 2007       11-02-2009, 10:31 AM Reply
SLingshot Recoil <---- #1
Ronix One/Ibex
Byerly Monarch
Old     (wakebrdr38)      Join Date: Sep 2006       11-02-2009, 11:29 AM Reply
I think the premier takes getting used to. It pops best with a real knees bent approach from what I have found. Same with the SS Recoil. But even those to boards ride a lot different. I jump back on my premier from my recoil every once in a while. The premier is definately faster than the recoil, i missed 4 double ups yesterday because I was early on the second roller, with my recoil if I miss it Im late. The premier rides totally different the more weight you put over the rear corner, which for me is annoying because I like a really centered (evenly weighted) approach
Old     (bflat53212)      Join Date: Mar 2003       11-02-2009, 11:32 AM Reply
Jason, the 08 and 09 Premier is significantly lighter than the 07. I was shocked when I rode the 08 after I needed to replace the 07.
Old     (dtownwakeboard)      Join Date: Mar 2007       11-02-2009, 2:00 PM Reply
+1 for slingshot recoil but just switched to a response 142 and i love it
Old     (hyperlite)      Join Date: May 2009       11-03-2009, 4:26 AM Reply
THE NEW B-SIDE IS INSANE. PICK IT UP.
Old     (lil_braswell)      Join Date: Aug 2005       11-03-2009, 6:58 AM Reply
The obrien decade rides very similar with more pop and softer landings. If you are lucky enough to have a dealer in the area check one out for sure!
Old     (innov8)      Join Date: May 2005       11-03-2009, 8:37 AM Reply
09 B-side or the new 2010 B-side.
Also the CWB Absolute.
(Message edited by innov8 on November 03, 2009)
Old     (wazzy)      Join Date: Nov 2001       11-03-2009, 9:46 AM Reply
Correct me if I am wrong but wasn't the GB Ricky G based off the premier?
