Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 16, 2009
Old     (24hog)      Join Date: Oct 2009       10-14-2009, 8:01 PM Reply
I have a set of o8 Murray boots and the base plate is too wide to use all the space options on liquid force and ronix boards. Is there another option on base plates for my boots or do I have to get a differn't brand of boots for these boards?
Thanks for any input.
Old     (zoodsmak)      Join Date: Feb 2009       10-15-2009, 7:58 AM Reply
As boot construction became smaller and lighter, companies decided to go to a smaller 6" hole pattern. Some companies changed from 8" to 7" some changed from 8" to 6", and some did it in different years, so its not a very clean and easy thing to figure out. For the most part it only effects riders who want to ride all the way out.
Generally speaking, any 07 and older boot will fit with any 07 and older board and pretty much any 09 board will fit with any 09 boot I think.
May be a good thing to cover in an article or in the buyers guide somewhere. I'm guessing we'll see less and less confusion after this transition is a couple years behind us.
Old     (24hog)      Join Date: Oct 2009       10-15-2009, 8:57 PM Reply
Thanks for the help. I like a more narrow stance but the boots only fit in one place, using the first and last hole.
Old     (zoodsmak)      Join Date: Feb 2009       10-16-2009, 6:35 AM Reply
I've only seen that issue with LF boards and 8" boots because LF put less inserts into the board last year. I believe there are 3 inserts on the outsides instead of 4 right? Not sure if we'll see more of that in 2010 or not.
Old     (hrwakeryder)      Join Date: Aug 2009       10-16-2009, 9:20 AM Reply
LF makes an adapter that possibly will work. I have 09 Lyman and use the 07 Transits. They work but only align in the widest set up witch if fine with me.
Old     (wakemitch)      Join Date: Jun 2005       10-16-2009, 9:45 AM Reply
Kevin, CWB also does the 3 on the outside 4 on the inside
Old     (borka)      Join Date: Jul 2006       10-16-2009, 10:31 AM Reply
Never combine a different brands stuff.
Old     (wakeandsnow27)      Join Date: Jun 2004       10-16-2009, 10:40 AM Reply
^ disagree.
Make what you like work.
Old     (24hog)      Join Date: Oct 2009       10-22-2009, 8:10 PM Reply
Do you know if the 09 Murrays are 6 or 8 inch? My 08's are 8 inch.
Old     (jamesz06)      Join Date: Apr 2007       10-23-2009, 3:10 PM Reply
Roy,
The 2009 Murrays are still gonna use the 8" spread. Hyperlite didn't switch to 6" until 2010.
Old     (24hog)      Join Date: Oct 2009       10-23-2009, 9:00 PM Reply
Thanks for the info!
