Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 15, 2009
Old     (acurtis_ttu)      Join Date: May 2004       01-20-2009, 6:03 AM Reply
Anyone know how to "smooth" voltage spikes and drops? I'm having some issues with a trim motor. Whenever the trim is used it pulls alot of power and drops voltage very low, causing some fuses to pop in acessories plugged into the cigareete lighter . Can I just add a small capcitor to the (+) side fo the cig. plug receptacle? what size? will this "smooth" the DC voltage?
Old     (spoonman)      Join Date: Aug 2005       01-20-2009, 6:13 AM Reply
Bigger battery or another battery also check your connections and cables to the trim. The battery is your best bet for a "sink" to absorb spikes
Old     (chpthril)      Join Date: Oct 2007       01-20-2009, 6:28 AM Reply
Sounds like you have a short or a bad trim motor. Low current doesn't blow fuses, excessive current draw does, but should only pop the fuse that is protecting the device with the higher then normal amp draw. A poor ground may be causing the trim pump to back-feed through other circuits.
Batteries or CAP's I dont believe will fix anything $.02
Old     (acurtis_ttu)      Join Date: May 2004       01-20-2009, 9:11 AM Reply
^^ I'll double check the grounds, and may upgrade them. Currently I think they are 6 guage? The motor works fine, but is drawing alot of current (must be in order to drop the voltage the way it is)
