A friend gave me 4 of these batteries and they weigh about 75 Lbs ea. I think they are used in cell towers. Any advantages / disadvantages to using in a boat?
http://www.northstarbattery.com/1.0....-542-03-04.pdf
Height 287 mm (11.3 in)
Width 108 mm (4.2 in)
Depth 396 mm (15.6 in)
Weight 34 kg (74 lbs)
Terminal Female M8 leak proof
Terminal Torque 8.0 Nm (71 in-lbs)
Measurements
International Standards 20°C (68°F) NA Standards 77°F (25°C)
8 hour capacity to 1.75 Volts/Cell 99 Ah 101 Ah
10 hour capacity to 1.80 Volts/Cell 100 Ah 101 Ah
Float Voltage 2.29 +/- 0.02 Volts/Cell 2.27 +/- 0.02 Volts/Cell
Nominal Voltage 12 V
Impedance (1kHz) 3.4 mΩ @ 25 °C (77 °F)
Conductance 1452 S
Short Circuit Current 3,500 A
Technical Specifications
NSB 100FT Silver
Product Data Sheet
NorthStar in the Americas
NorthStar Battery Company LLC
