The Vinyl Sauce actually works quite well as a carpet cleaner. I suggest wetting the area with clean water, apply Vinyl Sauce then scrub area with a soft bristle brush. Mop up excess with a wet towel and allow to dry.
One customer actually found a peanut butter & jelly sandwich face down on his carpet when he pulled it from storage in Havasu. Apparently his son had dropped it as they were putting away the boat 2 weeks prior and was too afraid to tell him
He pulled up the crusty mess and sprayed the area down with Vinyl Sauce and scrubbed with water and removed the stain. Even though it worked I still wouldn't recommend trying that yourself!
Originally Posted by joshugan
It says the vinyl sauce can be diluted. Is this recommended?
Vinyl Sauce may be diluted depending on your needs but we recommend using at full strength which is 100% safe for all vinyl, leather, and plastic surfaces. One way to make it last a bit longer is to spray some on a clean, damp towel for a quick interior wipedown as opposed to spraying directly on the interior then wiping if the boat isn't too dirty.
Zack Bale
www.boatbling.net
zack@boatbling.net
