Old     (superair502)      Join Date: Mar 2010       03-01-2011, 10:02 AM Reply
My question is are you guys piggybacking the wiring or running a power and ground distribution block type setup? Also are you tieing into anther 12+ somewhere or running a dedicated line straight to the battery? Thanks in advance. And no I dont want to run reversible/Jabsco pumps cuz I know someone will chime in with that
Old     (duffymahoney)      Join Date: Sep 2008       03-01-2011, 10:31 AM Reply
I run all my aerators to the distribution block. They don't draw a lot of amps so if you have room add them there. So both the negative and positive home runs for each pump. The wiring also doesn't need to be thick. A guy on here used to make wiring harness kits.
Old     (superair502)      Join Date: Mar 2010       03-01-2011, 10:39 AM Reply
where is the d block running straight to the batt? how are you turning the power to the switches on and off.
Old     (duffymahoney)      Join Date: Sep 2008       03-01-2011, 10:55 AM Reply
My fuse block is directly connected to the battery. The switches have postive and negative ran straight to them from the block. I can try and dig up a wiring diagram.
Old     (superair502)      Join Date: Mar 2010       03-01-2011, 6:57 PM Reply
So are the switches powered all the time then? I have the rocker style which is backlit and I was just curious because that would mean they would stay lit all the time
Old     (duffymahoney)      Join Date: Sep 2008       03-01-2011, 9:15 PM Reply
Only light up when switched on. Yes they are hot (or powered) all the time.
