Rent a fuel pump gauge and check on the fuel rail with engine on and with just key on. If it's not in your motors parameter its fuel related. Could also be tps sensor,iac valve,or anti syphon valve. Sputtering more often is electrical imo. And check every power and ground connection. If any are dirty or loose clean and fix.
