Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 30, 2009
Old     (cool232)      Join Date: Jan 2006       06-09-2009, 8:33 AM Reply
We are houseboating and want do some photos up close Any suggestions, thanks.
Old    dperizzolo            06-09-2009, 8:37 AM Reply
Use a waterproof camera, and make sure that the tube is either shorter than the wake line, or longer and that you have a good enough rider that they won't land on the rope
(Message edited by dperizzolo on June 09, 2009)
Old     (bmartin)      Join Date: Jan 2007       06-09-2009, 9:07 AM Reply
Tube rope shorter seems the way to go. Pull tube from ski eye or lower pylon, not tower. A little driver / tuber skill will be required so tube can stay in table and the rider will need to be consistent and be able to control ropes on pick ups and start with a little tube wash that is a little different but it is pretty simple and fun.
Old     (solo)      Join Date: Oct 2001       06-09-2009, 5:33 PM Reply
If you're going to shoot some tube shots, change up the angles a bit.* Have the rider pull you outside the wake for a different perspective.
Old     (wakerider111)      Join Date: Jul 2006       06-09-2009, 9:17 PM Reply
if the tube comes off the wake's table and you want to get it back, have the tube rider hold onto the wake rope and then the wakeboarder can pull the tuber back onto the table. this avoids the need to do power turns to fling the tube back onto the table. keep good communication when doing this of course
unless someone has a better idea? i have only done tube shots twice in my life... too little, need to do more.
