Old     (Luger)      Join Date: Jun 2015       06-08-2015, 12:41 PM Reply
I have a 2008 Calabria cal air direct drive, steering easy one way the other very difficult ??? Any ideas???
Old     (Pad1Tai)      Join Date: Jan 2013       06-08-2015, 12:46 PM Reply
cable... The prop thrust assist it in one direction..
Old     (K_Dubbs)      Join Date: Feb 2015       06-08-2015, 1:59 PM Reply
Bent rudder shaft, point it straight and check the angle it meets the hull when looking at it square from behind the transom or check the fulcrum of the cable where it is attached to the ram before the tiller arm, might be binding up if it is mis-positioned.
