1. This is the 3rd time this is happening to us, but we barely crawled back to the launch. After 30 minutes of surfing, with stock ballast full and about 8 people, my supra would not accelerate past 2000rpm. Very soon that limit dropped to 1500 rpm and by the time we reached the docks it barely went above 1000 rpm, almost idling. I disengaged the transmission and the engine is running fine, it accelerates smoothly up to 3-4000 rpm (did not try any higher). I also have a FAE installed, I hope it does not have to anything with it. The gas tank was full (since it happened to me yesterday towards the end of the riding day and I was running almost empty on gas), I made sure I filled up the tank today before going out. I believe it has something to do with the V-Drive or the transmission (not really sure what the difference is) but I know or sure it only happens when it's in gear. I will take it to the dealer on Tuesday (again after a leaky gas tank last month), but I would like to know if anyone can give me any hints... 2. Another issue that I have is that the port locker fat sac (250lbs) would not empty this evening, I cannot hear the noise from the pump when hitting the Left button(it works for the Front and Rear). I checked the fuses but none of them seem to be on the ballast system circuit. Again this is a Supra LAunch 21V 05. Thank you for your help!
