I have one of these on my x2 with a single axle trailer. My x2 is definitely on the upper end of the tongue weight where the trailer valet will work as the tires are at max inflation pressure and they still bulge. If you have a lip on your garage entrance...forget it. The tires can't get enough traction to make it over. In 2 years, the handle has broken off of mine and with it the brake system, and most of the bushings in the pivot mechanism are shot. It is just not quite up to handling a heavy wake boat, and I def think a 23 footer would be way too much for it. That said, I can get my boat in the garage in under 10 min (09 mc towers are not the easiest) and I can see how it is the greatest thing in the world for moving around a lighter boat. Hope this helps
