Mark, i'm not sure about a removable trim tab, but yes there are 2 types. One is a manual aluminum plate that is basically bent up or down with hand turned adjusters. I would bet that this is what is on the boat. You'll want it adjusted as far down as possible. You could also add weight to the front and restrict any weight in the rear and center tanks. However, this is a hardcore wakeboat with the hull being designed for maximum wake without a lot of ballast.
