Old     (FlyingWheels83)      Join Date: May 2011       08-03-2011, 1:16 PM Reply
I have a 1986 Supra Comp TS6M with a 351 5.8L Pleasurecraft V8. The boat ran great a few weeks ago when I took it out of the water. It sat in my driveway for a few weeks and wasn't touched. Now I cant get it started. The coil was split, I replaced it. It still has no spark from the coil though. Does anyone have a wiring diagram, ignition schematic, or any ideas? Anything helps....Thanks alot
Old     (chris4x4gill2)      Join Date: Sep 2009       08-03-2011, 2:25 PM Reply
do you have voltage to the coil? Where are you checking for spark from the coil?
Old     (mhunter)      Join Date: Mar 2008       08-03-2011, 8:04 PM Reply
Normally I would send you to the Supra forum . Are you running points? Check the coil pos and neg terms with a test light to ground . Key on engine off pos should be hot. Check the neg side wile cranking it should flash .
Old     (FlyingWheels83)      Join Date: May 2011       08-04-2011, 6:03 AM Reply
Not running points. If it doesnt flash are we condemning the electronic module and/or distributor? Also anyone have a wiring diagram?
Old     (chris4x4gill2)      Join Date: Sep 2009       08-04-2011, 11:53 AM Reply
you really need to get a volt meter and find where you have current and where you dont.
Old     (cadunkle)      Join Date: Jul 2009 Location: NJ       08-04-2011, 12:38 PM Reply
You have key on power to the coil and to the ignition pickup module? Breaker on back of engine is not tripped?
Old     (FlyingWheels83)      Join Date: May 2011       08-04-2011, 6:06 PM Reply
With key on, there is power to the coil. The breaker is not tripped
Old     (mhunter)      Join Date: Mar 2008       08-05-2011, 4:41 AM Reply
If you dont get a flash at the neg side of the coil when cranking you have a primary ignition problem. Check the module and pick up .
