Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 15, 2009
Old     (deltabri)      Join Date: Feb 2009       02-12-2009, 11:04 PM Reply
This is the setup I am going with. Other than fuses at the distribution block (for the amps) do I need to worry about power draw (when not in use? Should I add an inline switch / Breaker for this?
Old     (deltabri)      Join Date: Feb 2009       02-12-2009, 11:22 PM Reply
Also, What size power wire and fuses should I use? Amp1: JL 1000/1, Amp2 JL300/2, Amp3 90wx4. I may add a 4th amp in the future.
Old     (razzman)      Join Date: Dec 2006       02-13-2009, 5:53 AM Reply
I run the exact same Blue Sea system, I use thermal breakers on the batts to totally disconnect.
(Message edited by Razzman on February 13, 2009)
Old     (acurtis_ttu)      Join Date: May 2004       02-13-2009, 6:16 AM Reply
I'm with rassman, use some sort of breaker.
Don't use a switch.
The last 2-3 JL amps I've had, always drew power when they were off??? Never could figure it out. The amps always worked fine.
I thought it might be due to the fact you dont; necc. need a remote wire for turn on, they can be turned on via the RCA's ( voltage sensing)
Old     (deltabri)      Join Date: Feb 2009       02-13-2009, 8:52 AM Reply
Sweet, thanks. What size breaker?
Old     (deltabri)      Join Date: Feb 2009       02-13-2009, 8:59 AM Reply
Will this work? The largest I see in these is 150A. This is a Blue Sea.
