No, it's wider than the 12 by twice the beam angle yet still has the same penetration of up to 100' Model S 1206: (Bronze) spotlight strong narrow beam Will penetrate the water up to * 100 feet giving a crisp detailed view of submarine life. 6 LED – 18 watt, 45 degrees beam, draw only 1.5 Amp at 12 volts, 750 Lumens at 9000 Kelvin. Diameter 4 ½ (114 m/m) thickness 1” (25.4 m/m) Model S 1515: (Bronze) Powerful 15 LED flood angle will illuminate up to * 100 feet. 15 LED – 36 watt, 90 degree beam angle. Draw 3 Amp at 12 volts, 1610 Lumens at 8400 Kelvin. Diameter 5 3/4 (146 MM) thickness 11/16 (27 MM)
