It sounds like you're taking off with too much weight on your back foot. This will cause you to rotate and throw your balance off. A raley requires leaving the wake with more weight on your front foot than usual. If you can get some video of you doing the trick, look at it as you leave the wake and see if the nose of the board goes up. If it does, then put more weight on your front foot. The board should explode off of the wake directly behind you.
