Old     (dfe097)      Join Date: Oct 2013       12-30-2014, 3:03 AM Reply
Hello everbody i just got a new board, 2014 slab, and i went to put my ronix's on but the screws only went down a tiny bit then got stuck and obviously the binding were just flopping all over the shop. Can someone help me out?
Old     (boardjnky4)      Join Date: Dec 2011       12-30-2014, 6:19 AM Reply
The screws are too long. I've experienced this putting Ronix boots on an LF board. You have 2 options:
1 - If it's only a small gap, go to the hardware store and get a washer or two to make up the difference. This is what I did.
2 - Get shorter screws at the hardware store. Take the existing ones with you and find Stainless Steel M6 screws that are 1/8 to 1/4 inch shorter and that should also work.
edit: actually sounds like the screws might be the wrong thread. What exactly to you mean by "a tiny bit"? If I were you, I would go with option 2 above and just get some screws with proper length.
Old     (dfe097)      Join Date: Oct 2013       12-30-2014, 7:46 AM Reply
cool man i got it, i needed m6's the threads are all wrong. cheers anyway
Old     (boardjnky4)      Join Date: Dec 2011       12-30-2014, 10:46 AM Reply
yea second time I read it I figured that's what was happening.
