Old     (randyr12)      Join Date: Feb 2013       03-27-2014, 12:50 PM Reply
Does anyone know where to get replacement black flexible heating ducting for my heater?? I tried to order from boatheaters.com and I never got my order and no one will return my calls. BTW I have a 2011 Supra 22ssv with the factory heater.
Thanks!!
Old     (blackstang)      Join Date: Dec 2013       03-27-2014, 12:55 PM Reply
I would try Heater Craft. They are located in Rathdrum Idaho and have a decent website to order from.
Old     (soonerbilly)      Join Date: Jul 2013       03-27-2014, 7:33 PM Reply
Bakes carries the extendable tube with hose.
Old     (soonerbilly)      Join Date: Jul 2013       03-27-2014, 7:36 PM Reply
http://www.bakesonline.com/detail.aspx?ID=1390 hose
http://www.bakesonline.com/detail.aspx?ID=1058 extender tube
Old     (Boonejeepin)      Join Date: Oct 2012       03-27-2014, 8:02 PM Reply
I already have the hot tubes and I have a torn hose. Is it possible to replace just the hose portion of the hot tube?
Old     (shawndoggy)      Join Date: Nov 2009       03-27-2014, 8:10 PM Reply
yes, you can replace just the hose. You need to open up the hot tube enclosure, probably.
You can also get the 3" flexy hose from west marine.
Old     (Pad1Tai)      Join Date: Jan 2013       03-27-2014, 8:14 PM Reply
Unless you're an OEM kinda guy....
O'reilly's Auto Parts..... Fresh Air Hose..
They have it in longer lengths..
http://www.oreillyauto.com/site/c/de...fresh+air+hose
Old     (PotatoShack)      Join Date: Aug 2013       03-28-2014, 4:23 AM Reply
Look at the RV section of walmart. I used those sanitation hoses and they are way stronger the OEM and cheaper
Old     (shawndoggy)      Join Date: Nov 2009       03-28-2014, 5:24 AM Reply
you need a heat gun for these though to coax them into service for heater duty. They are ever-so-slightly smaller than the flexy stuff you get from heatercraft.
Old     (getssum)      Join Date: Jul 2005       03-28-2014, 4:48 PM Reply
I agree on the RV pooper hoses, way more durable. Get yourself some of the BIG Tie wraps to clamp them onto your ducts.
I would never put the standard hoses in again, they're just too fragile.
