You're the one I was talking about David!
I tried to get some answers on TMC.com but didn't get anywhere so I was trying my luck here.
I'm not sure how long it is costing me as it has always been this way. I don't have anything to measure it against. Either way though it's faster than manually connecting pumps each time.
So you've never noticed this happening? How long would you say it takes to fill both your tanks and sacs? I have the 400 pounders in the trunks. The only other thing I probably should change would be to put a loop in the sac overflow line. When the sac gets full then the sac exit point is the same height as the thru-hull overflow. Once you put gear on the sacs I lose some water out the sides. How do you manage this?
