Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 15, 2009
Old     (bruce1205)      Join Date: Feb 2009       02-12-2009, 6:34 AM Reply
I'm looking to put an abyss S 1206 B on the bottom of my 2008 X2. Has anyone seen an X-2 with a 1206 mounted on the bottom? Anyway I'm looking for an S 1206 B for under 300-.
Old     (hatepain)      Join Date: Aug 2006       02-12-2009, 6:51 AM Reply
If you are doing a single step to the S-1515b so you'll have a wider angle otherwise you should just get a couple 600's or even 800's.
Old     (wackbag)      Join Date: Feb 2009       02-13-2009, 8:32 PM Reply
I was thinking about doing the same thing.
Hate- are you saying the 1515 is too much of a straight or narrow beam of light?
Old     (hatepain)      Join Date: Aug 2006       02-14-2009, 7:54 AM Reply
No, it's wider than the 12 by twice the beam angle yet still has the same penetration of up to 100'
Model S 1206: (Bronze) spotlight strong narrow beam
Will penetrate the water up to * 100 feet giving
a crisp detailed view of submarine life.
6 LED – 18 watt, 45 degrees beam, draw only
1.5 Amp at 12 volts, 750 Lumens at 9000 Kelvin.
Diameter 4 ½ (114 m/m) thickness 1” (25.4 m/m)
Model S 1515: (Bronze) Powerful 15 LED flood angle will illuminate up to * 100 feet.
15 LED – 36 watt, 90 degree beam angle.
Draw 3 Amp at 12 volts, 1610 Lumens at 8400 Kelvin.
Diameter 5 3/4 (146 MM) thickness 11/16 (27 MM)
