The only problem I have with my '97 V210 is the the air bleed valves for the gas tank. They stick out about 3/4" from the side of the boat and when weighted heavily and on the inside of a turn they can take on water. This has resulted in water in my gas which is always a bad thing. The fix is to replace with flush mount valves (winter project) which I believe are standard on the new Sangers anyway. For surfing I usually have about 600 in the front locker and 350 in the rear locker and all the crew on the side I'm surfing on. I've found that the weight in front is as critical as the weight in the back for creating a wave that can sustain free surfing. I surf on the right hand side of the boat (facing the back of the boat) and have sustained 5 minute rides or better on my TrickBoardz wakesurfer. Good luck...
