Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 05, 2008
Old     (sdmjr)      Join Date: Jul 2007       06-03-2008, 5:37 PM Reply
I have a Roam and I took a really hard digger last time out on it. I only have one set of binding currently and have to switch them from the roam to my IBEX. I took the rear binding off and around the screw hole is a small crack. Is this trouble and should I return the board to hyperlite ?
What do you guys think? I know the roams are known for breaking I just don't want to be on it when it does.
Old     (srh00z)      Join Date: Jun 2003       06-03-2008, 6:01 PM Reply
The inserts ripped out of mine on a hard fall. There wasn't much holding them in there, so I would think this is probably suspect. You could try some resin, but that may be only temporary.
Old     (westsidarider)      Join Date: Feb 2003       06-03-2008, 7:05 PM Reply
yup the inserts are on their way out on your board. you can try taking it in to warranty it.
Old     (sdmjr)      Join Date: Jul 2007       06-03-2008, 7:56 PM Reply
Thanks Jason I hoped you would reply. I have seen so many posts of you only riding the roam as your main board so I thought you would know how to handel this problem.
Old     (ethan31)      Join Date: Jun 2007       06-03-2008, 8:21 PM Reply
I pulled my inserts out of my 05' roam, they replaced it.
The 07' is built like a tank.
I would call the place you bought it from they should warranty it if bought within the last year.
Old     (marvin)      Join Date: Aug 2006       06-03-2008, 8:43 PM Reply
I have destroyed two 07 Roams,,,, local dealer has always taken care of me on it. I love the board but I now use it as a second board.
Old     (westsidarider)      Join Date: Feb 2003       06-03-2008, 9:20 PM Reply
roams have the same lifetime warranty they rest of the boards do so long as you have not hit any rails. most of the time you dont even need to take it to the place you got it. take it to your local shop and if they have them in stock they should be able to swap it out right on the spot
Old     (andy_nintzel)      Join Date: Sep 2004 Location: Minnesnowda       06-04-2008, 5:54 AM Reply
Check out the O'brien R5, no wood! And a full slider warranty.
Old     (westsidarider)      Join Date: Feb 2003       06-04-2008, 4:34 PM Reply
obrien deffinately has the rest of the companies trumped with their warranty they have
