07-09-2007, 9:44 PM
My Wakeboard stance is Ducked, so...I m gonna snowboard for the first time and wanted to know if the bindings stance should be the same as wakeboarding. Thank you. Lucho
07-09-2007, 10:18 PM
I'd say yes, duck your snowboard stance as you would for wakeboarding, however depending on how wide your stance is wakeboarding, and your skill level, I wouldn't go quite as wide when first starting out... some may disagree but I like my snowboard stance a hair narrower than all the way out...
07-09-2007, 10:23 PM
wakeboarding i go all the way out, but may be a should try both...all the way and a lil narrower.
07-11-2007, 5:01 PM
note that snowboards do not put the screw holes symetrically on the board, if you put them on just like a wakeboard then you will have more of the snowboard to your left if you are a regular rider, you do not want this because you should be riding goofy as much as regular when you are on the snowboard
07-11-2007, 5:57 PM
I think thats what I meant to say, don't snowboard often, but do like to keep both bindings even distance from tip and tail respectively... good point joe
07-11-2007, 6:56 PM
It does not matter if you have more nose than tail. Setting up a snowboard cannot be compared to a wakeboard because they aren't meant to be perfectly assymetrical in nose and tail length. Hit some pow and tell me if you wish you had the same nose and tail length. The inserts are put on a snowboard for a reason. Do not look at how even the tail and nose are, go with the stance width you prefer at the PROPER holes. Peace
07-11-2007, 7:43 PM
ride a true twin snow board and you can set it up like your wakeboard.
07-11-2007, 9:30 PM
I ride a twin park snowboard and set up my stance as wide as possible but my duck on my snowboard isn't the same on each foot as it is on my wakeboard.
07-12-2007, 12:03 AM
Im not ducked on my snowboard. I tried even duck and it did not work for me at all So im about 15 out on the front and even on the back, rocks and I can ride switch easy. I think I might try the same on my wakeboard because riding switch on it is hard so maybe if Im even 0 on the rear foot that may help.
07-12-2007, 1:07 AM
same stance angles for me +15 front -9 back, why change? it's the same concept as far as edge control.. but a little wider stance on the wakeboard
07-12-2007, 1:32 AM
My s/b stance: 24 inches wide, angles 15/15 duck. On the wakeboard is the same.
07-12-2007, 4:37 AM
thanx guys, this really helps...people here told me that i was crazy because ducked was WRONG on a snowboard....but i thought if it is so confortable on a wakeboard, wy would it be so WRONG in the snow?
07-12-2007, 5:11 AM
if ur just starting might wanna keep in narrower but later on, max it out for them jibs
07-12-2007, 9:55 AM
Ducked wrong on a snowboard? Wow, sure a lot of people ride both bindings with a +ve angle, but no stance on a board is "wrong". If it's right for you then it's right for you. Case closed.
07-12-2007, 12:25 PM
i think shaun white ride 12 degrees ducked and I won't even tell him he is riding wrong LOL
