Old     (antoddio)      Join Date: Dec 2006       03-15-2014, 5:25 PM Reply
Looking to upgrade my sub. Right now I have the following amp on some 10'' sub I don't even remember. I was thinking of running one sub under the dash and one in the observers compartment. Is it possible to run 2 of the subs below with the following amp? Or so I need to throw down for another. All equipment that I buy will be exile. Thanks.
Kicker ZX750.1 Mono subwoofer amplifier
mono subwoofer amplifier
375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
variable low-pass filter (50-200 Hz at 24 dB per octave)
variable bass boost (0-18 dB at 40 Hz)
subsonic filter (12 dB at 25 Hz)
Class D design
CEA-2006 compliant
fuse rating: 40A x 2
Xi12D Xi Series - DVC 4 Ohm 12” Subwoofer
Power Handling: 600W rms / 1200W peak
Voice Coil: 2.5 inch OFC copper
SX12/SX12D SX Series - 4 Ohm 12” Subwoofer
Power Handling: 400W rms / 800W peak *Available as single and dual 4 ohm
Old     (antoddio)      Join Date: Dec 2006       03-15-2014, 5:39 PM Reply
Or just thinking of getting a Javelin amp to power the cabins and the sub. However not certain it can power 2 subs.
