Travis
yes they are similar, sure power has been around since 1959, they are the original battery isolator / separator inventors, you will see a lot of companies producing the same thing as sure power, Brett is correct with using that type of battery and i would also use the battery separator as well, it does not have a voltage drop like an isolator would. that is a great set up for running a dual battery set up....if you want more info about sure power products
http://www.ase-supply.com/Sure_Power_Isolators_kits_s/20.htm also that is a good price that brett has for you, the 1314.
Brett still going out xmas, its getting colder than a bit.h out here...
