Old     (ReSession)      Join Date: Apr 2010       08-18-2012, 5:43 AM Reply
My buddy and I have been talking about splitting the cost of a pontoon boat and converting it into a party barge, and we found a killer one for $5000 here in town - http://burlington.craigslist.org/boa/3201455066.html
The idea is to add more batteries, amps, speakers, lighting, DJ booth, BBQ, etc and moor it at his house, then just drive it over to the local beach we have our float parties at!
Just wondering if anyone has any experience converting a pontoon boat to a party barge (creating secure/dry areas to mount the stereo/speakers (there's no real rack on this one, so I'm guessing we'd have to fabricate something?).
Post some pics if you do (and yes, I did see that one in Cali that was just crazy overdone with the 16-18 tower speakers and green glow!)
Old     (kybool)      Join Date: Aug 2004       08-18-2012, 6:49 AM Reply
Gotta have a giant giraffe. Seriously, the tiki theme us pretty classic
http://www.geoffschultz.org/2010_Sai...1_13051782.JPG
Old     (882001)      Join Date: Nov 2003       08-18-2012, 7:20 AM Reply
i would think a honda eu2000i and some powered pa speakers would be easier than charging batterys all the time and having them die before the party is done, , . 5k for that seems high to me.
Old     (constructor)      Join Date: Aug 2012       08-18-2012, 7:55 AM Reply
here ya go LOL
http://www.youtube.com/watch?v=FJzSr3G61Bo
hold my beer and watch this!
Old     (882001)      Join Date: Nov 2003       08-18-2012, 8:19 AM Reply
http://www.youtube.com/watch?v=h7iV2si9QtQ
Old     (cowwboy)      Join Date: Jul 2008       08-20-2012, 6:46 AM Reply
Interesting idea but I'd personally would run a generator with true P/A equipment.
Used P/A equipment should be easy to find and is much better suited for the plan.
Old     (acurtis_ttu)      Join Date: May 2004       08-20-2012, 8:21 AM Reply
I did something similar.
The 35 hp motor is a turd. With anymore than 2-3 people, you’ll be luckily to break 10-12 mph. add some wind….and you’ll never be able to maneuver something that big. Into the wind expect max 10 mph, lol.
I had a 115, on a 23-24 ft…and it was slow. ( top speed with only a few people was about 22-25) . Those old two strokes suck gas too. I used to burn thru a ton of gas in mine…oil gets expensive.
I’d up your budget and get something a bit newer with more HP. Also those older pontoons are prone to leaking.
I mounted my amps in the drivers helm…I had two amps. I replaced all the cockpit speakers with JL components. (eBay) and mounted a free air sub in a box( decent sound). All marine grade….if you party on the boat, it’s gonna get wet. I had a bank of 4 golf cart batteries…the generator is a good idea. But not cost effective for me. Don’t’ hook anything up to the boat electrical system…you will fry the small stator in the motor. I also had a 25 inch LCD TV in mine (hooked into stereo)  had a portable HD antenna…worked great. Had LED lights around he flooring….used the outdoor ones with a 3m adhesive backing ( for under cars)
Had the bbq on the side…..didn’t’ use it near as much as I thought.
I even had an enclosure made for the rear half of the boat….great for winter/rain. Used a portable heater on board as well.
Same thing…I lived on the lake and kept mine at my house or friends houses. It probably got more use than my supra at the time.
They suck to drive in any windy conditions.
Old     (cowwboy)      Join Date: Jul 2008       08-20-2012, 9:03 AM Reply
http://cgi.ebay.com/ebaymotors/32-PO...item1c2a750bff
Thsi would be the perfect set up for what your wanting.
My mechanic has a older version of this he got cheap with a soft floor. He did like your wanting and gutted most of the overnight type stuff and made the kitchenette more of a bar. Then set up a rack mount audio system and had the huge sub enclosures in front of the enclosed part of the boat and a couple dual 15" full rang boxes on top of the building. All ran off the built in geenrator with a spare generator on the back deck.
Old     (timmyb)      Join Date: Apr 2007       08-20-2012, 11:08 AM Reply
There should be tons of resources out there. I remember going to Havasu and couldn't believe how many party barges there were! Disco balls, DJ speakers, couches, full bars, etc. There was some really cool stuff there!
Old     (miljack)      Join Date: Feb 2006       08-20-2012, 2:14 PM Reply
You will want to purchase a toon with the largest diameter logs you can find. If you're going to add all that stereo gear and lights, generators, etc...you'll need the buoyancy to handle it.
You can find deals on Crest (look for mid 90's and up III models or fishing models), and some Harris. Crest used wood in their seating, so they are heavy, but if you're stripping it out, that will save you weight, and the Crests are built like tanks.
Old     (mark197)      Join Date: Dec 2009       08-20-2012, 2:40 PM Reply
http://www.crankyape.com/default.asp...emNumber=34280
http://www.crankyape.com/default.asp...emNumber=35635
http://www.crankyape.com/default.asp...emNumber=33908
Old     (durty_curt)      Join Date: Apr 2008       08-20-2012, 2:45 PM Reply
You May have to get a cannon and take this one by force matey..
Old     (acurtis_ttu)      Join Date: May 2004       08-21-2012, 6:55 AM Reply
I had a regency suntracker party barge ( 25) Ther was no wood on the boat...all seat frames were plastic. even the floor was aluminum.
