Old     (brett_busby)      Join Date: Aug 2006       06-06-2011, 1:39 PM Reply
Wolfer thumps with no music playing.check the ground to battery and rca cords look good. first time out this year anything else to check? happens running or not.
Old     (hatepain)      Join Date: Aug 2006       06-06-2011, 2:00 PM Reply
Is Wolfer your dog?
Old     (murphy_smith)      Join Date: Dec 2005       06-06-2011, 2:09 PM Reply
ruff ruff!!! down boy
Old     (brett_busby)      Join Date: Aug 2006       06-06-2011, 2:54 PM Reply
Lol I even find humor in my texting. Can't believe I did that. Back to topic. Any ideas?
Old     (hatepain)      Join Date: Aug 2006       06-06-2011, 3:45 PM Reply
So is it just a constant thump or when you stop and start the boat?
Old     (brett_busby)      Join Date: Aug 2006       06-06-2011, 4:14 PM Reply
Its a constant thump, running or not. Comes and goes.
Old     (brett_busby)      Join Date: Aug 2006       06-06-2011, 4:16 PM Reply
No thump when start and stop
Old     (david_e_m)      Join Date: Jul 2008       06-06-2011, 4:49 PM Reply
Check the voltage at the amplifier primary terminals during operation.
Is it a less expensive amplifier without a self-protection circuit? Could be a bad amplifier.
Check the security of all primary connections at the power source and amplifier.
Bench check the amplifier out of the boat and off the boat system.
Unplug the RCAs and see if it still turns on. Maybe its dependent on the 'above ground' RCA shields because of a poor ground.
The repetitive 'thump' is usually kind of a power oscillation where the internal voltage sags and the amplifier turns off followed by a voltage rise where the amplifier turns back on and it rapidly continues to repeat the cycle.
David
Earmark Marine
Old     (UNvisible)      Join Date: May 2010       06-06-2011, 5:10 PM Reply
how big is the wolfer?
