Old     (svnfightsvn)      Join Date: Mar 2011       08-01-2016, 8:28 AM Reply
2007 vlx. I recently upgraded to a acme 1235 prop (was 537) and now it seems that my speed is way off. When I used to run 23mph or so, I now need to run at what is reading 27-28mph. Using a gps app on my phone, I can see that I'm really only doing the 23 like I was accustomed to. Has anyone had this happen? Is it because of the new prop with a lower pitch? Do I have to recalibrate my speedo? How do you go about doing that?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       08-01-2016, 12:06 PM Reply
no that doesn't make any sense.
if you're talking about PP speed, then yes you can calibrate
Old     (svnfightsvn)      Join Date: Mar 2011       08-01-2016, 12:13 PM Reply
Yes I'm talking perfect pass (or the Malibu version of it)
Old     (imscarlet)      Join Date: Mar 2008       08-01-2016, 12:37 PM Reply
Malibu and PerfectPass have owners manuals on line that tell you how to do it
Old     (Pad1Tai)      Join Date: Jan 2013       08-02-2016, 3:50 PM Reply
Upgrade to GPS perfect pass and delete the paddle wheel...
Old     (cadunkle)      Join Date: Jul 2009 Location: NJ       08-02-2016, 5:07 PM Reply
Totally unrelated to the prop change. Speedometers are either pitot, paddlewheel, or GPS. Not sure how you'd calibrate on aVLX. On my pitot speedometer (Airguide) there is a knob you turn to calibrate it. It can also read off if plugged, but changing to a tournament flow through style pitot fixed any plugging issues I had. My other speedo is on the Perfect Pass and is paddlewheel, there is a calibration for that buried in the PP menus, I check calibration of both to my phone GPS once a year when I'm on a lake, or if it ever seems off I verify at slack tide on the river. Charlie, GPS is not an upgrade over a paddlewheel for anyone on a river, tidal water, or anywhere with a current. I've been anchored and seen my paddlewheel reading 10 MPH when turning the key on.
Old     (chpthril)      Join Date: Oct 2007       08-02-2016, 5:38 PM Reply
Prop change does not require speedo-recal. Not like changing tire size on a truck.
