Old     (axeman)      Join Date: Aug 2009       04-09-2012, 6:03 PM Reply
Hey guys, I'm looking at boats in the $40k range and it looks like an 07-08 VLX is going to be the boat to get at that price point. Is there anything specific I should be looking for on these? Were there any specific changes in these or between these model years? Any insight or current/previous owners that can help shed some light on things to look for would greatly help out.
Thanks!
Old     (polarbill)      Join Date: Jun 2003       04-09-2012, 7:11 PM Reply
Those boats are near identical if I remember right. Make sure you are comparing wake hull to wake hull though. You could get the VLX with the diamond or wake hull.
Old     (joeshmoe)      Join Date: Jan 2003       04-09-2012, 7:23 PM Reply
make sure all eight water pumps are working before you purchase, pumps cost $50, not sure how much they cost to install. Should have extra ballast to go surfing, the back locker is huge area to fit the ballast.
Old     (axeman)      Join Date: Aug 2009       04-09-2012, 7:33 PM Reply
Thanks for the quick responses guys. I'm definitely looking at the wake hull not the diamond hull (no slalom here). Also, does $40k for these model years seem reasonable? I've found a couple 07s in the mid 40s with 200-300 hours. And the 08s are in the mid to high 40s
Old     (johnny_defacto)      Join Date: Sep 2006       04-09-2012, 7:37 PM Reply
3500 lbs at 23.6 mph at 80', no wedge = money.
Old     (ryanbush11)      Join Date: May 2003       04-09-2012, 7:39 PM Reply
40s for a well condition boat with a few options is a very good deal. i've been offered over 50 for my 08VLX with 420hours on it a couple of times this spring
Old     (ryanbush11)      Join Date: May 2003       04-09-2012, 7:40 PM Reply
spot on, although we run about 4000-4200 at 24.2-24.8 and it's insane!
not good pics but gives you an idea of the wake
Old     (ryanbush11)      Join Date: May 2003       04-10-2012, 7:23 AM Reply
The 08s had MUX switches where the 07s did not if i remember correctly
Old     (ord27)      Join Date: Oct 2005       04-10-2012, 7:33 AM Reply
the 07 was before the maliview. Also, the hammerhead didn't have the cat exhaust. If that's the engine you get, you will want the cats for surfing.
In Texas, $40 would be a bit high for an 07
Old     (bhyatt_ohp)      Join Date: Oct 2007       04-10-2012, 12:31 PM Reply
Thanks!
I ordered my 08 VLX March of 08, still have it and still love it. The hull is identical from 2005 to 2008 on the VLX's. If it is a true VLX, it will have the v25 wake hull, not the diamond hull available on the Sunscape models accessorized to look like a VLX. Even if you don't utilize the power wedge, I would be sure to buy one that has it as it will have better resale. Same goes for tandem axle trailer - these boats are heavy. If you run any weight or factory ballast with power wedge, you will want an Acme 1235 prop.
There are several things that are different in 2007 vs. 2008. As ryanbush11 mentioned, the dash went from toggle switches on the dash (2007) to MUX LED switches in 2008. The color of the gauges is also different in 2008 with a white/redish lighting opposed to the orange/redish lighting in 2007. The throttle is also different in 2008, although both 2007 and 2008 are both fly by wire. The glove box is billet and super heavy in 2007, where the 2008 is composite fiberglass and much lighter. The built in cooler flips toward the drivers seat in 2007, but flips toward you/middle of the boat in 2008, allowing the driver seat to swivel more when the cooler is open. Many 2007's didn't have the 2 speakers in the cutout area by the rear seat, instead this was a flip out cupholder option. 2008's had the 2 speakers in the rear seat area along with stereo remote option. Also in 2007, Malibu still housed the stereo/head unit in the driver's armrest area. In 2008, they went to a JBL/Malibu head unit with controls in the MUX switches and relocated the head unit to the left of the dash in bow walkway area. USB/Aux input was housed in the glove box.
Like I said, the hulls are identical from 2005-2008 but here are several changes throughout the years, not just 2007 vs. 2008. In 2005 the power wedge was not available, PW option started in 2006. 2005 and 2006 models have 3 split rear storage/engine access where 2007-2008 have two piece rear hatch design. Front ballast tank option was not available in 2005 i'm pretty sure. I'm sure I'm missing several other things, but thats about all i can remember. You will be happy with it no matter what year you buy.
Old     (johnny_defacto)      Join Date: Sep 2006       04-10-2012, 1:03 PM Reply
ryan... yep, thats it. Love that wake... do not get to ride it anymore as he sold it 2 years ago, but just looking at that boat and wake pics makes me smile.
Is that without wedge?
Old     (ryanbush11)      Join Date: May 2003       04-10-2012, 2:29 PM Reply
My 08 has the heavy billett glovebox door, i think it was an option
Old     (ryanbush11)      Join Date: May 2003       04-10-2012, 2:31 PM Reply
yeah that's without the wedge i've got almost 4200 in ballast, basically we load the boat down until it start to struggle to get on plane and back it off a little
also i'm running the OJ fusion frop with the monsoon
Old     (johnny_defacto)      Join Date: Sep 2006       04-10-2012, 2:56 PM Reply
yeah, I figured as much cuz it seems that when the wedge is deployed with a lot of weight it ruins the lip. My buddies manual wedge would sometimes drop into place when making tight turns... it made the lip foamy and soft. It sucked cuz we would have to stop and fix it. After a day of doing that, he ended up pulling it off.
I think your wake is sick.
Old     (fman)      Join Date: Nov 2008       04-10-2012, 4:35 PM Reply
Hey, is that a Nautique G23 wake for $100k less?!?!?!?!? who would have thought! That boat is going to be setting new records! That wake looks crazy! Cant go wrong with a Malibu, only downfall to the older VLX is the Illusion tower, it never seemed well built to me. In 2010 they went to the G3 tower.
Old     (johnny_defacto)      Join Date: Sep 2006       04-10-2012, 6:55 PM Reply
that.
Old     (axeman)      Join Date: Aug 2009       04-11-2012, 11:43 AM Reply
Thanks for all the responses guys. Bhyatt, thanks for the additional detailed information. Now I feel like I truly know the differences.
Ord27, I've only found 07s listed for 42-45. 08s for high 40s. That seemed high to me since back in 2009-2010 my buddy picked up an 05 for 35k from the dealer. He walked into the dealership and it had just been traded in that day. Lucky son of b****!!!
Anybody know anyone wanting to sell in the 30s or 40s range?
Old     (Brett_B)      Join Date: Sep 2010       04-11-2012, 11:59 AM Reply
The prices you are seeing are similar to what I found when looking as well. It seems that the used boat market dried up a bit in recent years. Most likely due to fewer people buying new boats with the economy downturn.
Old     (polarbill)      Join Date: Jun 2003       04-11-2012, 12:01 PM Reply
The used market in 08-10 was absolutely horrible for sellers. There were so many repo boats out there going for so cheap that it absolutely killed the used market. That probably has somethign to do with your friend getting sucha good deal. Right now the used market is pretty strong for the seller. Prices of new boats keep getting more and more expensive and good used prices aren't budging much. That is not so say you can't find an 07 or 08 for 40ish but you are going to have to be patient, willing to travel and jump on the boat immediately when a good deal pops up.
Old     (axeman)      Join Date: Aug 2009       04-11-2012, 12:36 PM Reply
I've contacted my local Malibu dealer and told them to keep me in the loop when they get any VLXs in for trade. Let's see what happens...
Old     (johnny_defacto)      Join Date: Sep 2006       04-11-2012, 12:46 PM Reply
axel, I ran into the same dilemma last year at this time when I was looking for boats. I too wanted a used vlx, but the prices for a 3-5 year old vlx was the same price as a brand new A22 (almost the exact wake), but the used boat would not have a warranty. A new V-ride 21 was about 5k more than the A22 as well. I couldn't find an 07-08 vlx for under 45K... it was shocking to me. Not saying this is the way you should go, just that I understand your pain.
Right now is a good time for the seller, not so good for you the buyer, but keep looking, I am sure something will come up, just be ready to pounce on it.
Old     (bhyatt_ohp)      Join Date: Oct 2007       04-11-2012, 1:12 PM Reply
I've seen 2005's sell for several thousands less than 2006-2008 models. 2005 is probably your best bet to get this hull sub $40k right now. 2005's didn't have the malibu speed control that you see in the 2006-2008 dash (perfect pass instead), no power wedge option, old school tribal graphics and had some of the problematic illusion towers that had cracking problems. Also the price of a 2005 VLX in 2005 vs. a 2007 VLX in 2007 differed by about $6k. When i bought in 08', costs had went up again another $7k or so vs. 2007. If i'm doing my math correctly, each new model year's cost has increased about 8% each year since then, now giving the VLX a price tag well into the $70k range and even the 2012 vRide (the 2005-2008 VLX hull) a price tag in the upper $60k range.
With boat companies charging so much for new boats in an unstable economy, used boats are really holding their value. My 2008 VLX has 380hrs on it and i wouldn't list it for sale for a penny under $48,900 right now. I've listed it for sale a couple of times and always end up pulling it off the market. Studying values over the last 3 years on my boat, it has only dropped $3k in value. Something to think about if you pay more for a nicer VLX, you'll get your money out of it later if you sell.
Old     (axeman)      Join Date: Aug 2009       04-11-2012, 1:13 PM Reply
I'm ready to pounce on it. Financing shouldn't be an issue since I've got great credit and I'm putting over 20% down. Wife is getting restless! We made the decision over the weekend to pull the trigger on a boat (we've been wanting to for over 3 years now). Every local one I found has already been sold (the ads were still up). Keeping my fingers crossed. At least I'm lucky enough where my wife is the one pushing to get the boat instead of having to convince her!
By the way, I looked at the Axis yesterday. Nice boat but I prefer the creature comforts of the Malibus.
Old     (johnny_defacto)      Join Date: Sep 2006       04-11-2012, 2:41 PM Reply
yep, my wife felt the same way. I think malibus are the most plush and comfortable wake boat of all, no contest.
what state are you in? and how far are you willing to travel? I see bu's a lot where I am at, I will keep my eyes open here in So Cal if that is not too far...
Old     (axeman)      Join Date: Aug 2009       04-11-2012, 5:56 PM Reply
I'm in Dallas, TX. I'd like to get something local but I'm willing to travel for the right deal...
Old     (johnny_defacto)      Join Date: Sep 2006       04-11-2012, 7:07 PM Reply
bummer. in just a few minutes I found about 4 VLX's from 39-47k, years 06-07. I have made that drive a couple times, 18 hours in a little rental car driving straight through... would be 24+ towing I would imagine. But for the right price it might be worth it. bring a buddy and spend a few days riding the lakes all along the way home.
Old     (axeman)      Join Date: Aug 2009       04-12-2012, 9:48 AM Reply
Can you PM the links?
Old     (axeman)      Join Date: Aug 2009       04-12-2012, 9:49 AM Reply
How does a 2010 vRide compare to an 07/08 VLX? Is it even the same hull?
Old     (bzubke1)      Join Date: Feb 2010       04-12-2012, 10:35 AM Reply
It's the same hull.
Old     (nitrousbird)      Join Date: Sep 2008       04-12-2012, 2:44 PM Reply
One thing the 05 offers the 06-08 doesn't is the LS1...the last year before Malibu decided to go backwards in motor technology for a couple of years.
Old     (axeman)      Join Date: Aug 2009       04-15-2012, 4:36 PM Reply
Can anyone name the pros/cons between an 07-08 VLX and an 08 SAN 210 TE? Not looking for a flame war here just pure facts.
Old     (johnny_defacto)      Join Date: Sep 2006       04-16-2012, 10:49 PM Reply
pm you the links.... just now noticed you specifically asked for 07-08... i found 3 2006's that can be had for under 40, nothing newer in the 40's
