Worm, I took a lot of time deciding on my HLCD's and the shape of the horn itself. If you are asking "Why the different shapes" then as mentioned already, it is to provide the different dispersion that your application requires. However, how it fits into you mounting space is also an issue. The compression dirver itself may be larger then you think. Mine are about 4 in. diameter and very heavy. So, Where you want the sound to go, space in the enclosure and on tower, and the looks are all the key points for the Horn selection IMO. If you don't like the appearance of a rectangular horn front near your round woofers, you could color the horns the same as the adjacent area to minimize the contrast. Just a little tease for some of you wanting to go this route. With all the hoopla after posting my stuff in July, I've been working on putting something together that is even better. I'm just about done with a very nice unit with Polished Chrome Cans, 2 Pro Audio 8's and a HLCDriver. Stay tuned, I should be done by New Years. Yes you can get a pair...I think you guys will be surprised. Good luck
