Old     (doubleup_dan)      Join Date: Oct 2006       01-21-2010, 9:46 AM Reply
Hey Im getting an x2. I dont know what prop it comes with but I plan on putting a 14.25x14.5 on it. Does any one have any experiance with this setup?
Old                01-21-2010, 10:42 AM Reply
What year x-2 are you getting? What motor?
Old     (doubleup_dan)      Join Date: Oct 2006       01-23-2010, 5:26 PM Reply
mcx new
Old     (witness140)      Join Date: Dec 2008       01-23-2010, 5:42 PM Reply
09' X2 with mCX has 14.75 x 15.5 OJ.
Old                01-25-2010, 3:35 AM Reply
The 14.75 X 15.5 is a very good all around prop. It will handle stock ballast loads very well. Before you consider a change in size, I would run the boat with the 14.75 X 15.5 and determine how it performs under the loads you typically run.
Old     (doubleup_dan)      Join Date: Oct 2006       01-25-2010, 6:43 PM Reply
I will be running it with as much weight as possible!! so I need the best prop for getting out of the hole
on my xstar I had a 14x14.25 or 14.25x14.50 (cant remember) and just wanted to know if it was the best for an x2 mcx as well??
(Message edited by doubleup_dan on January 25, 2010)
Old                01-26-2010, 3:18 AM Reply
The best prop we have for a real heavy load is the 14.75 X 13 LC 4-blade.
Old     (doubleup_dan)      Join Date: Oct 2006       01-27-2010, 8:46 PM Reply
Thanks alot Eric this is what I will be putting on my new boat!!!!
