New Post as of today:
I installed the Monster Tower:
I filled in cracks in the floor with a mixture of resin/hardner/filler. I then rolled out the entire floor with resin and hardner.
Recarpeted the entire boat in grey carpet. This included replacing the main floor board in the back, all 3 back boards that hide the gas tank (which including sanding the edge to taper the baord to fit into holding slots. The carpet ending up being a pretty big job given the replacement of wood and the resin/hardner work.
Problems:
I am having a major issue with the carpet on the floor. It's been raining everyday since laying the carpet on the floor of the boat. I don't have a garage to put this boat, but do have it covered. It has been hard keeping it completely dry. As such, parts of the carpet are wet. When I had stepped on it today, glue seeped through. I'm not sure it is ever going to dry now. I'm dreading the though of having to pull up the carpet on the floor and redo it.
Second problem. The piece between the main stringers in the back of the boat that I replaced ended up being a little short. There are little gaps, but really can't afford to redo this part. The 3/4" plywood is very expensive.
Most of this board will be covered up with the box and back seat I am building in the back, but it still bothers me.
I was planning on picking up the new vinyl seats and motor cover and putting them back in the boat, but the problem with the glue has slowed up this plan.
Later in the week I plan to start the ballast system.
I have cut the wood for the back box and back seat. Here is a picture of the current layout. I need to pickup another piece of 1/2" plywood to finish the front and back of the box and the front bottom of the seat. I will also be making a jumpseat to place right behind the drivers seat.
