Old     (rexlex01)      Join Date: Mar 2010       04-28-2015, 9:02 PM Reply
Which boat above will put out a more rampy wake compared to this boat below.
Old     (Nordicron)      Join Date: Aug 2011       04-29-2015, 8:33 AM Reply
Here's a 08 210:Name:  ImageUploadedByTapatalk1430321623.521055.jpg
Old     (rexlex01)      Join Date: Mar 2010       04-29-2015, 9:03 AM Reply
Thanks for the pic. Looks like it has a similar wake steepness angle and half pipe.
Not sure if its a $27000 wake upgrade to go from my '97 Sport Nautique to a 2008 210 since my boat has no ballast and 4 peeps in it.
Would be nice to see a 2005 - 07 VLX wake. Even an '04
Old     (sidekicknicholas)      Join Date: Mar 2007       04-29-2015, 9:39 AM Reply
I can snag a photo tonight if you want to see a 04' LSV wake with stock ballast + wedge
Old     (eubanks01)      Join Date: Jun 2001       04-29-2015, 10:21 AM Reply
Nick - You start weighting your boat yet? I have the same hull ('05 LSV) and I think the wake absolutely blows stock. I have 750's in the rear trunks (probably only fill to 500) and then add another 4-500 in the walkway or bow (depending on kids) and it's much, much better.
Old     (migs)      Join Date: Aug 2006 Location: SF Bay Area       04-29-2015, 10:25 AM Reply
The 210 wake will be Steeper than the VLX.
Rampier means less steep if that's what you are looking for.
So the VLX is rampier than the 210.
the 210 is steeper or more vertical than the VLX.
Old     (sidekicknicholas)      Join Date: Mar 2007       04-29-2015, 11:19 AM Reply
Not yet, I've been so busy with work haven't gotten a chance to figure out my pump issue.... hopefully just impellers bound up.
Hopefully this week / weekend I can get the pumps all working, then the plan is 600's or 750's in the rear using stock plumbing. Then after that look into the rest of the boat.
I'm hoping 750s rear + stock mid/front + a fat seat bottom that can either go on the floor or move under the seat for surfing if needed will be enough.
If you want rampy, any boat can do this, you'll just need to be extra heavy in the nose.
Rear weight = vert and eventually washes out
Front weight = mellows things out.
Old     (wakebordr11)      Join Date: May 2001       04-29-2015, 11:20 AM Reply
Looks like you are going 20-21 with a short rope on that sport nautique too - the shot of the 210 above I am betting is shot at 22+. Your sport wake is short and steep whereas the 210 is less abrupt.
Personally, I'd get a new prop for that sport and put 2k in it and let er rip
Old     (eubanks01)      Join Date: Jun 2001       04-29-2015, 11:44 AM Reply
You will want some weight up front...especially if you use the wedge.
Old     (tampawake)      Join Date: Mar 2008       04-29-2015, 1:28 PM Reply
Delta is right. I ride behind both the 210 more rampy than your SS. Love both but would kill for an 08 210. Until they are still not a fortune I am staying with my 02 xstar!
