Old     (RAMZAK)      Join Date: Aug 2014       04-15-2016, 7:31 AM Reply
Does anyone have a clue if 2 REV410's will fit a 2016 Mojo with the Aviator Tower?
Dealer just measured a boat on the show room and says there is 47" of straight tubing on the tower
Old     (DavidAnalog)      Join Date: Sep 2013       04-15-2016, 7:58 AM Reply
Not a clue but here are my thoughts. Two 28.5" wide speakers (ttl. 47" wide w/ no gap) should fit within a span of 47" straight tubing because the outside pod exteriors can extend beyond the mounting span and a bit under the outside tower radius. But that may not be the largest challenge. The dual collars per pod are in fixed locations and those collars must fit between any tubing that may run in the front/rear direction (if applicable to your tower). So I would get the exact spacing of the two collars per pod and match that up to the entire tower structure.
Old     (DavidAnalog)      Join Date: Sep 2013       04-15-2016, 8:05 AM Reply
Even something as small as a weld radius in a critical location can be a deciding factor.
