Old     (kgarr1986)      Join Date: Aug 2007       08-01-2016, 3:54 PM Reply
Somewhat new to wakesurfing and trying to stick a surface 360. I cant seem to get the full rotation down without having the board squirting out underneath me. Any suggestion that may help would be appreciated! video attached
Old     (SethP)      Join Date: Jul 2016       08-02-2016, 8:09 AM Reply
I'm not very consistent with threes but I can get them maybe every other try. I would say don't throw it so hard. You don't need to spin as fast as you think you do. That's what helped me the most, anyway. Just focus on staying low and balanced and try to see the boat while looking over your back shoulder and that should bring you around at least. Hope this made sense.
Old     (Haecker)      Join Date: May 2016       08-08-2016, 10:48 AM Reply
I am far from landing this trick consistently but I have gotten more successful by doing the following: Pick a spot closer to the back corner of the boat (out in the flat) to initiate your turn as opposed to starting closer to the wake behind the center of the boat. This will put you in a little better position when the wave catches up to you and you won't be sliding down the face of it when your back is to the boat.
