Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through July 06, 2004
Old    aaron14            06-30-2004, 7:52 PM Reply
I ride a cwb sol 133 behind a boat w/ a knee high wake no pylon and still can barely clear the wake. If i buy a absolute build a pylon and ballast my boat w/ about 1500 pounds from plastic drums will this improve my hangtime and how much air i can get?
Old     (dococ)      Join Date: Mar 2002       06-30-2004, 8:27 PM Reply
Aaron, if you are barely clearing the wake with a knee high wake, then there is something wrong with your cut, and you are not loading the line properly. You can buy a million dollars worth of equipment, but it will not correct for poor technique. I mean no disrespect!!! I simply encourage you to get someone to work with you on your cut and pop (which you might well accomplish for free), rather than keep spending money on more equipment. Expensive equipment cannot teach you proper technique, it just comes with instruction and practice. Again, I mean no disrespect. We all have had to go through the process of learning, but there is no need to waste money in the process. Once you get your proper technique dialed in, then you can worry about extra toys and gadgets. One piece of equipment that you DO need at this stage of the game is a zero-stretch line if you are not already using one.
