Originally Posted by boardjnky4
He doesn't have a traditional "remote" lead, since he's not running a headunit.
OP, my suggestion to you would be to actually add a switch to your dashboard for music. That way you can control the stereo on/off independently of any other systems.
Obviously, but he still needs a switched remote lead. From the sounds of it, it seems like he has both the power and the remote in on both set to a constant 12v source.
Originally Posted by chpthril
You need to connect the EQ's B+ to the same source as the amps' B+ and then use a rocker switch to trigger the EQ and amps' turn-on circuit .
Exactly, he needs a switch.
