Old     (tantrum999)      Join Date: Jun 2003       07-20-2009, 7:56 AM Reply
perfect pass on a 2001 wont hold speed. im a boarder and i am scrubbing 2 mph at least off the speed when i cut out when it used to be rock solid. its had a new paddle wheeel and the system is about 7 years old. any ideas? servo?
Old     (tantrum999)      Join Date: Jun 2003       07-20-2009, 7:59 AM Reply
if i remember rightly its wakeboard pro. all the settings where defaulted but still the same after i put the settings up. i couoldnt pull anything off it before. the lake is too small to run in rev based mode so SPEED only
Old     (acurtis_ttu)      Join Date: May 2004       07-20-2009, 8:34 AM Reply
return spring may be going bad, cheap replacement.
Old     (wake26)      Join Date: Mar 2009       07-20-2009, 9:15 AM Reply
I've been having the same problem PP told me that they think it is the electronic part of the paddle wheel that went bad. it is one of the only things that I have not replaced on the PP system.
Old     (tantrum999)      Join Date: Jun 2003       07-20-2009, 9:40 AM Reply
Great to get such a quick response! the return spring looked fine but yes i will check if tired. the paddle wheel was replaced 2 months or so ago so guess it wont be that as the sign on the dash says its reading. what about a Tired servo??? the boat has been uused very regular for 7 years wiht the system?
Old     (lav)      Join Date: Jun 2007       07-20-2009, 9:42 AM Reply
+ 1 for return spring
Old     (showmedonttellme)      Join Date: Mar 2008       07-20-2009, 10:01 AM Reply
You adding more weight these days? Its most likely the spring the fellas are talking about....but I know that when you add more weight or move from a lake to a river, you really have to adjust the nn and kvm settings to account for the extra uummpphh you need.
Old     (tantrum999)      Join Date: Jun 2003       07-20-2009, 10:12 AM Reply
Hiya same weight for the past three years, same lake same values. on a small lake i cant chane the nn rate because it s a small lake and swings really bad. it was always fine though thats what i dont understand. when put in rev mode it keeps not bad speed but not acceptable for any decent boarder going upside down.
