Old     (fman)      Join Date: Nov 2008       07-17-2009, 10:29 PM Reply
Anyone used "3M 4200 Marine Adhesive" before? I am going to remove my intake grate and re-install, West Marin said this stuff works well and should seal up the grate with no leakage. Just wanted to find out if anyone has used it before and what were the results. Everything else I have used by 3M has been great.
Old     (tro)      Join Date: May 2009       07-17-2009, 10:32 PM Reply
i've used 5200 before and that stuff is off the hook for sealing below and above the water line. not sure about 4200 though.
Old     (jetskiprosx)      Join Date: Aug 2004       07-18-2009, 8:19 AM Reply
I used 3M 5200 when I put in my ballast thru hull below the water line on our last boat.
Old     (masonwakerider)      Join Date: May 2003       07-18-2009, 9:25 AM Reply
5200 in not considered to be removable, 4200 is a slightly softer version for use in applications that are not permanent. Both can be used under the waterline.
Old     (ottog1979)      Join Date: Apr 2007       07-18-2009, 10:04 AM Reply
Used 4200 to attache my depth finder to the inside bottom of my hull and this stuff is the shizz! Make sure to clean & degrease the area it will adhere to. Acetone ought to do the trick.
Old     (puckinshat)      Join Date: Sep 2003       07-18-2009, 10:12 AM Reply
3M marine adhesive is the best out there, that simple. I have used the 4200 to seal the new brackets for my swim deck. Easy to work with and does the job perfectly.
Old     (duffy)      Join Date: Feb 2006       07-18-2009, 10:18 AM Reply
How are you guys dispensing the 5200? I bought some from Home Depot and it didn't work well in a cocking gun...
Old     (mikeski)      Join Date: Aug 2003       07-18-2009, 10:20 AM Reply
Caulking gun, the other one sounds like something else...
sorry, I am not the grammer police but I though that one was funny.
Old     (fman)      Join Date: Nov 2008       07-18-2009, 10:53 PM Reply
Considering Wakemakers.com said I could use the 3200 series, I am assuming the 4200 series should only be better? They did have the 5200, but I thought "permanent" was a little to aggressive if I ever wanted to remove the intake grate again.
Old     (cyclonecj)      Join Date: Jul 2001       07-19-2009, 6:48 AM Reply
Use brake cleaner on a paper towel and you can clean that stuff off nicely while it's wet.
Old     (otown_dave)      Join Date: Dec 2007       07-19-2009, 8:39 PM Reply
The 4200 is fast cure, When you do not want to wait the 7 day full cure time of the 5200....
Old     (fman)      Join Date: Nov 2008       07-19-2009, 8:42 PM Reply
Perfect, thanks to all who replied, appreciate all the feedback. Went ahead and used it today, should dry quickly in the 100+ degree heat!
Old     (tride)      Join Date: Aug 2007       07-20-2009, 5:43 AM Reply
5200 come's in fast cure also!
Old     (chaser)      Join Date: Sep 2006       07-20-2009, 8:11 AM Reply
so the 4200 isn't permanent. Is there any trick to removing it when it comes time?
